I have rebuilt the water pump on a 1993 40 HP Johnson model TJ40ELETB and reinstalled it. In the kit there were two rubber grommets that I couldn't figure out where they went so I left them off thinking they were probably to be used on different model. The The part # on the rebuild kit is 0438592, the Johnson kit. In this kit there were two grommets the size of the shaft. one came in the bag with the impeller so I put it in the recess on the lower side of the impeller. The other one I have no idea where it goes since there is not a recess in the shaft anywhere to put it. The third grommet is approximately 2" diameter and again I have no idea where it would have gone. The kit I removed was totally different than the new one I got. The new one has a solid impeller housing while the old one is like the parts diagram with round plate and liner. None of these grommets were used in the installation of the old Kit. Have I left something out or do I fill it with grease and move on. Any help would be appreciated.
