1999 Johnson 40HP (oil inject disconnected) on pontoon. - 2 Problems
Choke or primer system clicks but does nothing.
There is that red shutoff or valve and tire filler type valve.
What do they do? Could that red lever be positioned wrong?
And does that choke system go out or need repair? any thoughts on why it's not working?
Probably not related but could be if it's sucking air in or something...
The engine will run at a higher RPM but not run when idled down.
I have taken both carbs apart and cleaned them.
Is there something I may be missing getting cleaned out when it comes to the low speed jets or needles?
I guess I'm guessing it's fuel related and not electrical because it runs fine at higher rpms. But I could be wrong.
Thanks for any thoughts or help
Ron
Ron
