Hello all,
This is my first post to this forum, or any forum for that matter.
I have a 40 HP Evinrude outboard, i believe it is a 1992. I'm not sure off the top of my head, and i'm at work so i can't check at the moment.
The motor is on a 1994 24' Crestliner pontoon.
The motor has a VRO fuel pump. The oil intake has been deactivated, adequately sealed and wiring disconnected. I am pre-mixing 50:1
The issue i am having is that the motor often has difficulty starting, needing to be put in advance throttle and choked to get started. Once started, it often will eventually sputter and die at an idle. PUMPING THE PRIMER BULB DOES NOT HELP OR HURT
While in the water, when put in gear and fully throttled up, the engine will only run forward to what seems to be 50% full rpm, like it is only at half throttle. If throttled up in neutral or reverse, the engine will scream no problem. HOWEVER, when on the trailer with the muffs on, the engine will run fine in forward, reverse, or neutral.
Here is the work that i have had done/done myself, to avoid repetitiveness:
Rebuilt current VRO fuel pump with kit purchased online
Replaced all fuel line, primer bulb,fuel filter, and connections from fuel pump to tank
Removed tank and cleaned
Spark plugs have been frequently changed
Both cylinders firing when checked while running
I have had it to a marine mechanic twice and he said "It runs fine", but without running it in the water. I realize the mechanic clearly isn't very thorough. I guess thats it for now, what do you think?
