Andrew and Hamish
Motor was over heating replaced water pump,impeller thermostat, took head off replaced head gasket as water in top cylinder,torqued head back on to specs. Done compression test 125 both cylinders,new plugs,cleaned carbies with lots of help from here.
Motor starts and runs easy, engine warm, idles on two cylinders. Pumps plenty of water. But when put into gear and throttled up it starts spluttering going from one to two cylinders ,reving up and down without touching control once in gear. At idle can remove either plug lead and motor still idles ok. All done on earmuffs.
Tried early on in bay motor idles good but when put under load in gear it struggles to go feels like it running on one cylinder I could row faster.
Could it be the coil or something electrical causeing problem. Also checked plugs they were dry.
Can anyone help once again.Cheers Andrew.
