40 HP 2001 TRACKER ALARM SOUNDS CONSTANTLY
tgmcree
I WAS RUNNING AT WO THROTTLE W
I WAS RUNNING AT WO THROTTLE WARNING ALARM CAME ON STEADY AND I SHUT IT OFF. NOW WHENEVER THE KEY IS IN THE ON POSITION THE ALARM IS ON CONSTANTLY OIL TANK IS 1/2 FULL AND WATER TELL TALE IS PUTTING OUT A GOOD STREAM
THE REPAIR FOR THIS PROBLEM WA
THE REPAIR FOR THIS PROBLEM WAS THE OIL LEVEL SENSOR . THE OIL TANK HAD A MAGNET BREAK LOOSE ON THE FLOAT THIS TRICKED THE SENSOR. THE REPAIR WAS TO REPLACE THE OIL TANK AND THE SENSOR WAS FINE
