Background: Boat purchased, previous owner ran nothing but non ethanol gas, I have done the same. Boat ran fine on test drive. Boat ran fine for 2 weeks after purchase. Yesterday I was cruising 12-15 mph, and appeared to run out of gas. Changed tanks like normal primed it yadda yadda... boat would crank run a few minutes sound like it was starving for fuel then die. Prime it again choke it crank it run good for 5 minutes sound like it was starving for fuel then die again. Basically I limped it back to the dock like this. The boat has never been run over about 15 mph. Now trying to repair it the float ball (primer bulb, whatever you call it) you can prime it but never seems to tighten up. I replaced this thinking bad ball, same results.
checked the fuel filter and cleaned it, not bad but did it anyway. Still having the same issue. So before I randomly start replacing parts such as fuel pump, etc would anybody have a suggestion?
