I’ve replaced all within the last year to year an half
points an conds
Plugs
Water pump
Rebuilt fuel pump
Fuel lines
Gas tank an primer
Rebuilt carb an replaced high speed
jet, an low speed seal around needle
She been running the best but was coming around the lake an it lost power it droped
Down to 20 mph, (gps on phone ) took it back to lake once I pulled carb off an checked for trash found nothin adjust float while I was there it was off a little, ran like crap again no power not turning full RPM so I said whatever fished anyway, started hearing bubbling in fuel tank, vent was open thought it was weird
So I started looking an pressure was coming out of the pickup side of the gas tank on the check ball area, took cap off whatever drove other side of clove wind was terrible
So I banked it got out an fished had the motor raised up (Manuel) well I fished a hour or so on way back to ramp she ran back full rpm no issue, thought she was fixed. Took it back out that weekend, seemed weaker. I’m lost on what to check, planning on checking compression, but I did take plugs out the button plug look to have water in it/
On it? May have head gasket issue not sure
Any help would greatly appreciate
points an conds
Plugs
Water pump
Rebuilt fuel pump
Fuel lines
Gas tank an primer
