B
Bailey Henry
Guest
"I have a '96 Mariner, inl
"I have a '96 Mariner, inline four with constant ratio oil pump. When it sits for more than a couple of weeks oil gravity feeds thru the pump into fuel line and eventualy the tank if the fuel line is left attached. I expect this is a common problem, a real pain to start and clear out after it sits a few weeks. I think I would like to disable the oil pump and go to premix, but I'm open to sugestions if there is a fix for this. If I disable the pump do I need to remove the drive gear and shaft? Or is it enough to just close the inlet and outlet lines?
Thanks,
Banjo"
Thanks,
Banjo"
