"Performance comparisons betwe
"Performance comparisons between a direct injected 200 horse 2 stroke and a 4 stroke.
I just picked up some recently published tests. They compared a 200 horse 4 stroke Yami and 200 horse DFI 2 stroke Optimax.
The motors were mounted on new Wellcraft 21 footers of similar dry weight/rigging. The one noticable difference was the amount of fuel on board. The Yami kitted boat had 25 gallons in the tank, the Merc about 70 (or approx 300 pounds more weight).
So not a perfectly scientific comparison, but some "real life" tests.
The conclusions - the Opti's top speed (even with 300 extra pounds on board) is a little faster than the Yami (about 2 mph) but it burns 3 more gph at top end.
However, when you compare apples to apples, at 42.4/43.9 mph they burn 17.4/17.0 gph each (the Opti is a touch slower, but put 2 more adults on the Yami (or 300 pounds of fuel) and see what happens.
Best cruise speed/gph/mpg
Yami - 26.2 mph @ 4000 rpms burning 8.1 gph (3.23 mpg)
Opti - 32.2 mph @ 4000 rpms burning 10.8 gph (2.99 mpg)
The Yami would have to run at little above 4500 rpms to keep up with the Merc, and guess what, would burn a little over 10 gph - or alternately, the Opti could slow down to the Yami's cruise speed, but would still burn 9.4 gph (or about 16% more fuel).
What did surprise me a little was the hole shot - the Yami got the boat on plane .1 sec quicker than the Merc (again though, the extra weight probably played in a bit) - but what surprised me even more was the fact that the Yami took 2 extra seconds (9 vs 7) to get to 30 mph - that's close to 25% slower even though it planed out at about the same time (strange), would have expected the "band" to be quite similar once both motors were up and going...
Anyhow, here's the actual results - first the Yami...
