"Nelson, unless you had intent
"Nelson, unless you had intentions of replacing the motor all together, which I probably wouldn't do myself, you may want to investigate if a shaft extension kit is available.
Since you note that your biggest issue is the motor breaking the surface when running in rough water, an extra 5 inches of shaft may make a world of difference.
Aside saving your motor from an early grave, due to lack of cooling water when it sucks air, keeping the prop in the water will obviously make a big difference in forward thrust.
I am not aware of a factory kit to extend the shaft lenght for the 8 horses (have seen them for the 9.9/15's), but Just In Time may know.
Alternately, you could look at simply lowering the mount a few inches (or use an adjustable kicker mount), which could be used as conditions dictate."
