tcuduckhunter
I have had someone look at the motor and they have rebuilt carbs, checked compression, and the spark plus were firing when he used a remote starter. However the engine does not seem to fire when the key is turned. The mechanic has said something about the electronic control module, but is not sure if that is it.
A little background on the motor: The motor had been sitting for a while and I had it running in my drive way(with water attached). Everything was fine until I put a new propeller on the motor. Once I did that, I started the engine again and ran it for about a minute. About that time there was a loud sound (as if you tried to start an engine with a semi dead battery and it has half a crank) and the engine shut off. Now we cant get the motor started again.
Any suggestions?
Any suggestions?
