Tipster1947
Mercury 1999 IE4L Model 100421 VK
Carb – KEIHIN F520C ML09
This engine was submerged in brackish water for two weeks after Hurricane Sandy. It started and ran afterwords, but we had other priorities. Then it wouldn't run at all. After cleaning carb it now starts readily and runs at medium and high speed but it does not idle well. I’ve flushed out every tiny opening I can find, but I was unable to remove the bronze nozzle which covers the access to what I believe is the man jet. It is corroded in place. Only a destructive will remove it.
Is there anything else that could be causing this problem?
Do I persist with this or just replace entire carb.
Thanks!
Thanks!
