4 cylinder volvo
ryno1981
"how can i tell exactaly what
"how can i tell exactaly what engine i have it says volvo on the top but there are no other numbers other that the valve specs, the outdrive is a 270 just need to know so i can buy parts thanks"
"Try comparing pictures on the
"Try comparing pictures on the volvo website. If it's a 4 cylinder, you have a few options as to which one it is....."
Or just look on the bellhousin
Or just look on the bellhousing/ above the starter motor. Should say exactly which model it is
"On the volvo four cyl, there
"On the volvo four cyl, there should be a brass tag on the side of the engine block just in front of the starter."
thanks i found out that i have
thanks i found out that i have a 125a not sure if that is good or bad yet although i do have a couple questions for you guys. i have a omc 3.0 also and it dosn't have the resivoir tank on it that the volvo has this may be a dumb question but do i supossed to fill that with coolant? or water or should it fill itself when in the water thanks for taking time to explain to my dumb butt
yes fill 50/50 coolant/water.
yes fill 50/50 coolant/water. There are two systems fresh and raw water... That tank is for the fresh water system which will remain full once you fill it. The raw water will be pumped from the outside water and used to cool the fresh water coolant
"You dont fill the tank with t
"You dont fill the tank with the strainer, that is a chamber that the water from the outside passes through. It passes through a pipe that runs through your other tank and cools the tank.
It then passes through your exhaust manifold and expels through your leg and through one or two outlets on the transom.
I think so anyways."
thanks guys know i probably so
thanks guys know i probably sound stupid by asking these questions but i have never worked with this type of motor before
"No such thing as a stupid que
"No such thing as a stupid question Ryan. Answers..well that's something else
Cheers, Tom"
