Hi everyone,
I have a Crownline w/ a 4.3L V6 Mercruiser with a Thunderbolt IV ignition.
It’s always taken a bit of throttle to get the boat to run,but now I can’t get the boat to stay running at all. It turns over, no problem but wont run.
I can get the boat to fire using starting fluid but it won’tstay running. This first made me think that the boat had spark, but wasn’tgetting fuel. So, I pulled the fuel lineoff and checked that there was fuel at least getting to the carb and there wasfuel pressure there.
I noticed that the gas coming out of the fuel line didn’tsmell great, so I pulled the fuel-water separator thinking there could be waterin the gas or the fuel was dirty.
I poured the contents of the separator into a dry waterbottle and easily 60% of the content was water and the rest of the content wasclean fuel.
I drained the entire fuel tank until it was empty andreplaced the fuel water separator. I tried starting the boat and had the sameissue. It would only run on starting fluid.
I next thought that the spark plugs might be fouled from thewater so I replaced them all with brank new NGK. Same problem, it will only runoff starting fluid so I’m still thinking that it’s not getting fuel.
What other things could I be missing? What would cause theboat to not be getting fuel like it should?
Any help troubleshooting would be greatly appreciated!
Recap:
Recap:
- Drained fuel
- Replaced fuel-water separator
- Checked for fuel pressure at gas line into carb
- Runs off starting fluid
- Replaced spark plugs
