Today I took the boat out for a last run for the season. it's been several weeks since I've had it out but it ran great the last time out. Last night we had a cold snap so I put a heater under the boat cover (19ft bowrider). The outside temp was only 2 degrees below freezing for only 2 hrs so I thought the heater would be fine.
Anyway, I had it on the boat ramp and tried to start before unhooking the boat as usual. It was very difficult to crank so I gave it some extra fuel. It finally cranked over but ran rough with lots of smoke. I also noticed a sheen on the water that looked oily. When I returned to idle it stalled. After about 5 minutes of this I decided not to chance a trip out and came home to winterize the boat. The water that I drained out was very dark with an oily sheen on the surface.
What can I do to begin to troubleshoot this problem? Will I cause further damage to try to run it in the driveway with the muffs on? Thank you for your help and suggestions.
