I'm getting horrible*fuel economy (1.43 to 1.75 mpg) from my inboard motor.**Here is what I'm operating.* I have a 1997 GM 4.3L. motor pushing a 21' full cabined Bayliner.* The Motor was installed in 2006.* It has a Holly 2 barrel carburetor (Model 2300) which I replaced last year,*the cooling system is enclosed (raw water through a heat exchanger then out the exhaust manifolds). I replaced both exhaust manifolds in 2008.*I'm running*the boat*in the cold--cold waters of Prince William Sound, Alaska.* Water temp is probably close to 42 degrees.* Temp indicator (for the motor) reads 175 degrees when warmed up and doesn't change too much no matter where the throttle is placed.*
*Last year I was having a horrible time getting the motor started but after*warming it up, it ran fine.* I changed the carburetor which helped some and I estimated my mileage at approximately 2.2 to 2.5 mpg. *I further had (and still have) a problem with run-on when I try to shut*down the motor from a normal cursing speed.* --like, I have to let*the motor idle for approximately 2 or 3 minutes before I shut it off*to keep it from "dieseling"**Last fall I took the motor to a mechanic who adjusted the carb and further noted to me that the timing was off.* He adjusted the*distributor and carb which made the engine start easier but the run-on at shutdown has persisted.* I further noticed that when I start the motor cold, I get a lot of smoke which*lasts for about 30 seconds.* Once the motor is warmed up, no smoke and it appears to run fine, except for the mileage and run-on at shutdown.* I have not noticed any decrease in oil level over a 107 mile trip and don't believe I'm burning oil.* Rather, I think maybe the carb is adjusted to rich...maybe?
*Does anyone know what the mileage for a 4.3L should be?* I'm cursing the boat at approximately*3700 RPM @ 25 to 26 mph, calm seas, with no more than 2' waves for the last couple outings and*I've managed to stay on step while cursing for the fuel estimates.* I can full throttle the motor*at 4600 RPM and get 29 mph on a dead calm day.** ...with the price of gas these days, this mileage thing is killing me.
