I have a '88 4.3 Mercruiser. I switched the fuel pump to an electronic fuel pump because the mechanical pump was too expensive at the time. I'm wondering if I missed up here. We took it out, and getting up to plane it began to struggle and overheat. I figured it was a carb issue, since we just pulled this boat out of the back pasture after sitting for 2 years. I got everything tore down, then realized on the side of the carb, there is a port for what I believe would be high input fuel? My electronic pump does not connect to that port on the side of the carb. It does start and idles just fine. Would that cause the motor to weaken and overheat at higher RPM?
I know the overheating isn't a cooling issue. I have a new impeller, manifolds and risers have been checked. Trying to figure out the motor weakening and over heating.
Thank you. I am a mechanic, but I am not a marine mechanic so I'm learning as I go.
