The Lazy G
Had a cracked block and replaced the engine with a new remanufactured unit. As everything was functioning properly my mechanic put everything from other engine on new block. Break in seemed to go well but as i wrapped it up and began normal use the issue began. Starts, idles and runs fine till about 3,000rpm then cuts out and starts to balk. Replaced fuel pump, lines and filter. Cleaned carb, plugs and wires are good. Could the Endlebock Carb be worn out? Or could this be some kind of electrical problem. Original engine was a 1988 so other parts could be original. Guess lesson to be learned: spend the money and replace it all. Any thoughts would be appreciated.
Thank You
Thank You
