Hi guys, i'm new here and i am having a problem with my boat. I have a 4.3 Mercruiser which has started to have difficulty starting. When it does start it seems to idle lower than normal and runs kind of rough. When you try to give it gas it will stall out unless you work the throttle back and forth ever so slightly until you get the RPMs up to around 900. Once you get the RPMs up the boat will run but still seems a little weak. When starting the motor and trying to get the RPMs up you can smell gas and at times see white smoke coming from behind the boat. Thank you for reading my post any help would be greatly appreciated.
