Chaparral1930
I'm getting water in a couple of the cylinders of a 1995 4.3 Vortec. The boat was running fine all summer, but one day it was running full speed and then it just started to sputter and slow down until water/oil mixture (whitish color) came out everywhere! I had the oil changed two times and it started up again, but it ran so rough that I had to turn it off. After dry-docking it and running it with a hose hooked up, I shut it off then I took the spark plugs out again and there was water in the chambers. It looked like the back two cylinders. A mechanic said its shot. Even though it has normal compression. Is it shot? Is it cheaper to rebuild or swap out to a 5.7? Thanks
