safdchief18
Bought this boat earlier this summer. Has not ran well yet. Continuing to correct issues.
I have a 1989 4.3 with the Thunderbolt IV. Starts and idles great but has no power. I've replaced the water separator, cleaned the carburetor, replaced the plugs, replaced the ignition module because I had no spark advance and double checked firing order is correct. Checked timing at idle in gear, about 650 rpm the timing is at 10 degrees BTDC. I know it should be 8 degrees, haven't adjusted that yet. Rev engine up to 2500 rpm and the timing advances as it should now after module replacement.
Took the boat for a test run today, and get's up on plane now, but very slowly. I have to advance the throttle slowly or it will bog and pop. I can get to about 3000 to 3500 rpm but when trying to go any faster I get the symptoms you hear in the video at the link below. If I go to WOT I continue to lose speed. Get back to about 3500 rpm and she cruises smooth as can be with no issues. Just can't go faster.
I'm not sure what to check next.
Please help!
Video link here:
Please help!
Video link here:
