"Did YOU buy the boat new from
"Did YOU buy the boat new from a MerCruiser dealer?
This engine was never Registered from new.
You should try to go back to the dealer you bought it from and have them register the Engine, Drive and Transom. If that can't be done then you will want to find a different MerCruiser dealer that is well known in your area to do a good job and take it to them and have them Register your boat with MerCruiser and have them fix it also, You may need your new boat contract, Or proof of purchase date to you. Now the warranty will normaly be up to two years after the day you bought the boat from new, But you will want to look on the contract to see if the dealer sold you a Product Protection warranty for a few more years, If not then this would be a good time to try to get one
I would not go back to them guys if I was you. Take a look at this link at punch in your zip code and see what other dealers could help you out if you can't go back to the dealer where the boat came from.
http://direct.where2getit.com/cwc/apps/w2gi.php?&client=mercurymarine&template=s earch. If you need to use a different dealer then try to find a Premier Service dealer in your area to help you out, You will be better off. Below is your info. You will want to try to do this as soon as you can. Good luck.
ENG serial#: 1A046517 Model# 42110G5US 1998M MERCRUISER 4.3L ALPHA 1.7R 4.3L ALPHA
NOT REGISTERED
Warranty Period: NONE
Product Protection Period: NONE
Manufacture Date: 04/09/2007
Date Type Dealer Information Misc. Information
04/27/2007 INVOICED ORD : 2571498-000"
