BoatService
Hi.
My boat runs fine up to 2950 rpm. When I reach 3000 it cuts off instantly, as if you turned the key off. Engine restarts no problem and runs fine until 3000, when it cuts off again. This happened 4 times on the same outing, Limped home with lower revs. Attached a TechMate pro and got fault codes 42 (electric spark timing fault) and 43 (electric spark control fault). Fuel tank, hoses and filters all good. Where do I go from here?
Max
Max
