"(1)4.3L omc would not
"(1)4.3L omc would not go into reverse. Would go foward and neutral. Then got stuck in forward and only after runing awhile and throtle up and down could I get out o gear. Now it will not go into forward or reverse.I took the cover off at the shift cables where they go to the lower unit and it seems they are tight and not broken.Any other sugestions. I read about the fluid being full, could this be the oroblem of not going in gear?
(2)The trim on this boat lifts and lowers the front of the engine. I never seen any thing like this.The pump lifts it to put the I/o in but seems to let it drop down . Will not hold it up. I am assuming I might need some o rings or fluid but can not seem to find the resivoir. I also have had no luck on finding any infp about this type of trim. I called a few parts places and most have no clue. Any info woul be greatly appreciated."
