Hi all,
Looking for some advice and also hoping this might help someone somewhere in the future...
For reference I'm mechanically inclined but don't really know what i'm doing.
I've been helping someone with a 383 Mag Stroker having consistent hot start issues for 2 years(!!) now:
Engine starts cold perfectly, runs perfectly with no power issues but shut it down hot (even with 15min idling cool down and hatch open) and it refuses to restart normally, even if done immediately
It is possible to restart by doing a clear-flood (full throttle) start but if you miss that then it flat out refuses to restart whatever you do until it totally cools Next morning it fires right up at idle.
Checked a lot of things... fuel pressure and leak down, coolant temp sensor resistance, replaced TPS, bled off a load of fuel from the rail to try and eliminate vapour lock but problem remained. It's been scanned by Mercruiser dealer and nothing other than replace TPS advice.
With the help of this forum I found a post regarding the ICM getting hot, after a hard run I felt the ICM and it was warm rather than hot but I tried something weird which was to spray canned air (Staples keyboard cleaner) upside down to give a cooling but not wet blast to the ICM and the Aluminum fins next to it - the engine starter perfectly at idle.
Any recommendations for better fixes than cooling the ICM with canned air?!
Checking grounds? Repotting ICM on silver thermal paste? Replacing ICM but after 2 years probably would have failed by now?
Thanks!
Thanks!
