38 DGES jetting for AQ151C
Sorry - ignore my other post. I have the 38 DGES and am trying to get it set up with an AQ151C. Any help with jet sizes would be appreciated. Currently the engine runs until the choke is fully open then dies and won't restart until it cools down again.
Turn both mixture screws until they seat and then out 1.5 turns. Turn the idle speed screw out until it no longer touches the cam, then turn in 1 turn. If after you did this and it still won't run, then you have some vacuum leaks. Once you eliminated all the leaks and get it running OK, then go through the set-up as described in the instructions. Your jetting should be OK to at least get it running provided there are no vacuum leaks. Once you set it up properly the instructions will tell you based on the settings whether or not you need to increase jet size.
Good luck
