skyman2112
Hi group, i was told the beeping is from the error code "maximum number of misfires reached" Sometimes i just get 1 long beep when i first start the engine. but then it doesnt beep again for a day or 2. Sometimes it gives 1 long beep while underway, and then it keeps beeping a single time, every minute. At which point i replace some parts, go to the dealer to clear the code, then try to take it on the lake again.
So far I replaced the spark plugs, cap, rotor, and main engine fuse to no avail. Even threw in a new battery for good measure.
Also found a loose grounding lug for the engine harness on the back of the engine just below the coil. was thinking maybe it damaged the coil by having a loose ground. Tightened that and no change.Noticed a little white oxidation on the inside of some of the spark plug boots where they connect to the cap, didnt look excessive but im thinking maybe its enough to throw a code.
Was told the crank trigger connector has issues with making good contact with the pins, may try to tweak that or change the spark plug wires next. Anyone has any clues on what could be causing this? I ran it up to 3000rpm in a test tank at the dealer and of course it wouldnt do it then. It did show some misfires even at idle though in some but not all of the cylinders. Hope to get some new ideas, thanks to all! 2011 Crownline 21SS, engine s/n 1A645849, Bravo 1. 330 hours.
