atilla_boy
I couldn't figure out how
I couldn't figure out how to get it off Mine is the reverse threaded one. there is an allen bolt or something in the center of the impeller that I striped out so a began drilling it to use an eazy-out and I guess while dioing the drilling the heat must have loosened it up cause after i drilled it I tryed one more time to loosen the impeller and it came right of. now what do I do about the hole I drilled will it be ok to just reinstall or what. It never came free from the impeller(the bolt or what ever you call it so should i just reinstall it. I am dioning this cause the 2 seals are being replaced due to water comming from the weep hole.
