"1978 360 chrysler. I have an
"1978 360 chrysler. I have an oil leak where the oil filter adapter mates with the block. I replaced the gasket last fall at lay up. Thought I had it fixed. First good run and it's back. Four hours underway @3000 rpm and I found a half pint or so of oil in the drip pan. Observed leak at gasket and also dripping from under the head of the large mounting bolt. New gaskets are on the way, (thank you David Kain) Any thoughts on a sealer or ? Jack"
