360 head differences
W
will c
Guest
"Hello i was wondering about t
"Hello i was wondering about the interchangeability of the heads of 360 motors. I have a roller cam non-magnum 360 are the heads the same as a regular 360?
thanks, will"
"Good question. I know the Mag
"Good question. I know the Magnum heads are different in the intake/ exhaust port areas, but they supposedly bolt up to the older blocks. I suggest you buy a set of head gaskets for the "new" heads and see if all the passages line up.
You might also post this question of the Slantsix Forum. They are Mopar experts for more than the crooked sixes.
Jeff"
"thanks jeff. The roller cam e
"thanks jeff. The roller cam engine I have is a 1989 and before magnum was introduced. I know it uses the same intake and valve covers as the earlier 360s so I think they older heads should work but I will make sure on slant six.
thanks, will"
