360 Hard to start
liddlebit
"I have twin 360's in a 73
"I have twin 360's in a 73 Luhrs. After running one engine for a while and then letting is sit, it is hard to start. I believe it is vapor lock. I have fram fuel filters for both engnes and an AC filter inline at the carbs.
Any ideas on how to prevent vapor lock ??"
"You could try a wet (with
"You could try a wet (with water or even some ice) rag wrapped around fuel line, inline filter, and pump.
Does it crank slower when you try to restart?
Is the problem engine running hotter than the other?"
"The engine runs at normal Tem
"The engine runs at normal Temp, about 160 and it cranks fine. Putting a cold rag on the fuel line might work, but when fishing and have to start the engine back up, Opening the hatch and putting a cloth on the fuel lines would be a hassel."
The cold rag idea is just to t
The cold rag idea is just to test your vapor lock suspicion. You might even try a fan or a "cool can" from a speed shop.
If your engine runs at normal temps I can't see it vapor locking and the other not. When you shut down does fuel boil out of the carb into the intake?
"Here I go again! (Maybe
"Here I go again! (Maybe I should make a copy of it...)
You can not put fuel filters (fine filtration) BEFORE a fuel pump. Stack fifty of them AFTER the pump and it'll still work, but not before it! Only coarse (30 micron or greater) filtration can go before a pump or you will have vapor lock.
Jeff"
