351 cobra outdrive won't shift to forward
limbclimber 001
The shifter started getting hard to move the last few times I was out,one time it wouldn't come out of reverse but after a few moves on the shifter it came out and went forward.Now it won't shift into forward at all.could the shifter cause all of this.
It could be the shifter but a lot of times it's the lower shift cable itself (between engine and drive), either out of adjustment or binding and needs to be replaced. I think the cable is in the $100 range and the mechanic will probably need 3 - 4 hrs?
Anyone can do it print it out read and re-read it, if you don't do it then give it to the mechanic.
Stuart writes about every aspect, best written i have ever seen, on this subject.
That the reason i gave you the link.
the mechanic who is familiar with the boat comes today and I will pass on the link.thanks so much for the link. I will learn about this boat just like I did when I had my Volvo Penta and got all my help here,I never had to take it in because of the detailed help.
