350CID will not idle
bschip43
"I picked up this used 350 wit
"I picked up this used 350 with 4barrel carb dropped it in, hooked up and it will not idle..Everthing seems ok..What should I be looking for????"
"The idle "circuit" is
"The idle "circuit" is actually a passage that bypasses the throttle plate and provides a richer mixture. What may have happened is that crud from ethanol ended up blocking this system which on most engines is not a straight passage inside the carb. If you are qualified, rebuild the carb.
Other possibilities: Air leak around the secondary butterfly, just plain mis adjustment of the idle mixture/set point, or timing problems."
Thanks for this information an
Thanks for this information and help..I'll take the carb off and do a rebuild...Will keep you posted...
