350 Sputters and Surges underway
J
josh hudgens
Guest
"I have a 26ft Harkers Island
"I have a 26ft Harkers Island boat with a rebuilt 350 Crusader. The engine starts with no problem. It revs up to 4000rpms in neutral and sound great. However when I run it on the water it will not go beyond 2800. It sputters and surges.It runs a little better at very low speeds but still a bit rough.I put in a new water/fuel separator and new gas. Also checked rotor and cleaned contacts well.It has been running great for the last 3 months.Not sure if it's the timing, plugs or what.
Not sure why it run well in neutral and not under load."
"See of the timing is advancin
"See of the timing is advancing as it should--they tend to rust and stick. Time it, and also see if the carb secondaries are opening.
Jeff"
I would check for a loose or b
I would check for a loose or bad wire or a cracked distributor cap it would be great if you could look at the engine while under load it sounds like something may be arching to ground.
