Good day I am a newbe to this forum and boats, but I am a motor head from way back. I bought a wellcraft 260 aftcabin this summer ( or to the point bartered). after installing a new fuel pump it fires right up and runs great in tub.(i don't really like muffs). Everytime I take it out it will olny tack up to around 1800rpm's. Will run allday like that, dosn't overheat, oil pressure is fine, dosn't spit or sputter.
I have replaced carb, plugs, water pickup, spark plugs, fuel pump filter water seperator fuel lines cleaned pickup in tank, and changed all fluids. paperwork says it is a mercruiser 260R which is a gm motor (5.7) 350. The ignition system has been changed to a dual point distributor set up. The previous owner replaced motor two years ago but is no mechanic ( he did not do swap) He used the boat this year but was burning up coils. I replaced plugs with spares in boat ( have whole bin full of spare parts). Was looking up new wires this morning and lookrd up app. for plugs and found they were for stock app. not points, mabey coil two. so I bought new coil,wires plugs and pvc filters.
I no this a lot of BS BUT COULD THAT BE PART OF PROBLEM. i LiKE TO READ AN DO RESHERSE. hAVE READ(Ops) all I can find on low Rpm's. and am aware of most. any help would be most appreciated. and also I posted a simaler question on omc page by mistake but motors thge same. and is my outdrive a alpha one or what.
