My boat (Proline 2950) has a couple merc 350 I/O's with fresh water cooling. It has engine driven power steering, with both engines pressurizing the system, and both PS pumps share an external reservoir. I had some hydraulic fluid leaks due to over-heating of the PS system, which warped the external reservior (Latham style acrylic cylinder between alum plates with o-rings). The system was installed a few years ago, and for some reason no PS oil coolers were installed, so I am trying to get them installed. My mechanic said it would be very expensive (labor), because he said the oil coolers had to be located at the back of engine where the seawater intake comes from the sterndrive. Access is poor back there.
I would think the oil cooler could be placed in the seawater line just before it enters the fresh-water cooling heat exchanger. The exchanger is at the front of the engine, close to the power steering pump. This would also make it much easier to hook up the hydraulic line (low pressure return line to the PS pump) to the oil cooler. Am I missing something?
thanks,
Roger
thanks,
Roger
