thanks ricardo,how far should i run out the all thread.i heard 1/2 inch on 350 5.7.im in the dark here as this is my first try at this procedure. is the goal to determine if the har bal is true and stable,and to get a true tdc.correct me if im wrong.thanks
I would not be able to suggest a dimension! You will just have to experiment, and learn approximately where the piston will be stopped in relationship to crankshaft angle!
The angle itself is not important. It could be 27° BTDC and ATDC, or it could be 31° BTDC and ATDC!
The important part is that you give it enough spread as to create accuracy when this angle is "split"!
Example:
If we used 8* BTDC and ATDC, we would be too close to the top of the crankshaft throw.
If we increase this angle BTDC and ATDC, we gain accuracy when the angle is split in half!
Ideally, a degree wheel and temporary pointer are used when doing a positive piston stop procedure.
The pointer is moved until we see the same angle being shown at BTDC and ATDC.
Once this has been achieved, the piston stop is removed, and we then roll the engine over until the pointer aligns with zero on the degree wheel.
Theoretically, we now have a true TDC!
We then re-mark the balancer for TDC as per our timing tab location.
You can then "stake" the balancer in two locations, so that it can be checked in the future to see whether not it continues to slip!
If the two stake markings continue to align, all is good!
But I agree...... we are getting off track here!
You need to focus on why this engine is not firing for you.
Even if your timing marks are not completely accurate, I would suggest that you bring it around to #1 cylinder TDC on the compression stroke.
Remove your distributor cap, and check to see if the rotor is aligned with the cap plug wire socket that leads to cylinder number one.
That would be a good starting point!
Yes..... Pun intended!
