Hello , Tried starting my 350 with the muffs on water on gently, it locked up and would not spin, removed the plugs and found water in back cylinders.
This happened before and I had the flapper valves replaced and the riser gaskets replaced. Ran good last summer.
What other source of water can enter cylinders when the muffs are on ? It has freshwater cooling too. Engine spins over with plugs out.
I want to try this : Replace plugs and start motor a few seconds with muff water off, as soon as it starts then I am going to turn the water on so I dont ruin the impeller.
Any input will be appreciated as the marine dealer is treating me like the Golden Goose.
