"Hi Folks,
I recently purch
"Hi Folks,
I recently purchased a 98 Mariah with a Mercruiser 350 Magnum (5.7) from a trusted source. While doing the season open maintenance I noticed a couple of hair lines about 2-3" in length. I scraped away what paint I could just to see if it might be just a paint defect but the lines are embedded in the block. The lines run front to back about an inch below the cylinder head in the middle of the block (water jacket area). My fear of course is these may be cracks in the block possibly due to poor winterization, which could lead to other component issues as well. My questions are;
How can I determine if these are in fact actually cracks and not just some casting, handling, or other kind of superficial mark?
Is there a test kit such as a magna-flux or facsimile that I can purchase to determine this?
Could they simply be handling marks form a jig used to install the engine at the factory?
Is it possible that even though there is no apparent leakage externally and no apparent contamination of engine oil, that it could still be cracked?
Is there anyone out there who would be able to recommend repairing as opposed to replacement?
If in fact they are cracks, should I insist on a PCM engine as a replacement or is there an alternative of equal quality?
Thanks in advance for your helpful advise!"
I recently purch
"Hi Folks,
