Not sure why, but my fuel injected 350 MAG will not come up to temp. I originally thought the gauge was bad and then sending unit. I checked the gauge and then replaced the sending unit and still the gauge doesn't move. I even bought a manual temp gauge and installed it in an extra 1/2" port right next to sending unit. Still no movement on either gauge. Changed thermostat thinking it was sticking open; still no change. Because the computer looks at temp for fuel curve, I am running rich at all times which is causing the engine to bog down. I look at the water flow diagram a cant make sense of it. the water has to come through the thermostat housing to exit through exhaust. Could there be another path the water can flow besides through thermostat? I guess it could be worst, I could be running hot. put 2 160 deg thermostats in and cant get the temp above 100 deg. The engine runs as cool as a cucumber. Has anybody seen this? Its probably simple. This is on a 01 Tige direct drive.
