350 Mag - Fuel Pressure Problems
partycove2
Hello,, Sorry for the long thread but I am having a problem that I hope someone can shed some light on.
My set up is twin 350 Mag MPI (SN 1A066746), last year the Stbd engine died on me going at no wake idle, it restarted for a moment then died again then would not restart. Troubleshooting I found I could make it run off the left tank but not the right tank. Cleaned the right tank anti-siphon valve and all was good for the last month of the season.
Now this year, launched the boat was idling out and again same engine died. This time I replaced the anti-siphon valve but it did not solve the problem. I again could get it to run on the left tank (after allot of bleeding the system) but then switched back to right tank and in about 30 secs I could see the pressure dropping and engine died. I thought I had it narrowed down to the right tank again but the strange thing is now I cannot get any pressure using either tank. Today I am going to run the port engine off the right tank just to make sure it does not die.
So here is what the pressures read with the gauge hooked up on the fuel rail.
- key on (not started) is intermittent, sometimes 0-10 and sometimes it comes right up to approx 40
- when the key on pressure is 40, it will start and the pressure drops down to around 35, revving it goes back up to around 40.
- I checked this against the other engine and it seems the same.
So now that I seem to be getting no fuel to that engine from either tank, I suspect a fuel pump problem which I where I need help.
I assume the low pressure pulls fuel from the tank and then the high pressure sends it to the ejectors
- When does the low press pump run and when does the high pressure run?
- How to I determine if it is the low not pulling fuel in or high not sending it to the rail?
- Where is the fuel pump relay located
- Is there a fuse for the pumps?
- This has the older gen 3 cool fuel assy, is it possible to replace only the pumps in this or does the whole assy have to be replaced?
Today I plan on pulling the filter out and check it and the disc filter in the bottom but looking for other ideas
I pulled the top regulator last year to check for paint and it was clean, did not check the regulator on the cool fuel assy
Thanks, Jeff
