"I bought a new 3.5 back in Au
"I bought a new 3.5 back in August of 2007. At first the motor ran fine, but after about 3 months use it started to stall after running for about 10 or 15 minutes. I took it to the dealer and he replaced the coil. Now after a month or so it is doing it again, but it takes about 30 minutes of running. I also notice that the water coming out of the tube never changes tempture. It is always the same temp as the water temp going in. The engine seems to be hot at times even though the water pump is working. Also if I run the engine hard for much time it starts to loose RPM until it stalls. It is like it is getting hot and the piston is swelling. If I take the top off and let it cool for about 3 or 4 minutes it starts right up again. Any suggestions?"
