"I wrote a while back seeking
"I wrote a while back seeking advice on how to remove the lower unit on my 1986 35 Merc. I tried tying a come-a-long to the lower unit, nothing. I tried working it off with the nuts using wedges, I deformed the nuts. Tried hanging it up-side-down by the lower unit for about a month, nothing. One suggestion was to run the motor....which I did today, only for a couple of minutes because I didn't get any "tell Tale" flow. I disconnected the tell tale line from the block and still no water.....I put a wire in the hole and still nothing. Then, I took the water intake off and found pieces of the impeller. I don't want to run the motor anymore until I get the impeller replaced.....HELP! Thanks! Spring is coming!!!"
