" I have an early Force 35HP o
" I have an early Force 35HP outboard.
Was running boat the other day at WOT. Motor started to lose power as if I was cutting throttle. Then couldn't restart the motor.
Found a leak in the fuel bulb, and replaced the line from the tank to the motor. Also checked and tightened all clamps in the fuel system onboard the motor itself. Checked the tank, carb-bowl, fuel pick-up, fuel-pump filter for dirt and found none. Problem happened again, and it was very difficult to restart the motor again.
I have also recently replaced the plugs, and the spark plug boots.
I have never had starting problems with this motor, it always started on the first crank - hot or cold. This season however, it has been harder to start than ever before.
Any suggestions would be appreciated. "
