35 hp evinrude 1976
robweb
ok I am not a geneious , motor fully tuned up new coils points plug and condensers , runs fine low idle , also full power in neutral , when in full powers runs at half speed , then full speed , sprayed carb cleaner , put sea foam in gas still the same , trying not to rebuild carb , any pointers or suggestions ? Thanks
It will go to " full power " in neutral running on 1 cylinder.------Does spark jump a gap of 3/8" on both leads, yes or no ?
engine now does not turn over , starter engages half turn and stops , also throttle control is stuck and woot engage in gear
Yep more than likely , and I did the tune up , probably not right , this site sucks to hard to navigate , I will be bringing boat to marina and have so called pros fix it , to many xperts with smart ass questions for me , Thanks
Define a " smart ass " question.------From a 1000 miles away you need to describe the symptoms to folks who can then advise based on the facts about your motor.----No one can see , hear or touch your motor on the computer screen.----Best to visit the shop in this case.----Pay the man.
