It's been running fine all season, then last week after it was running it won't start. Key turns, no click, nothing.
Checked and replaced in-line fuse, checked big red plug connector - clean, checked and charged battery (12.5v), used a multi-meter and narrowed it down to either the ignition (after getting the engine to turnover by jumping via the solenoid) or the solenoid.
Replaced the solenoid, same problem, nothing, no click.
Used another shift/key control box, and just plugged in the big red cable, nothing, same problem, no click (also thought that it might be the neutral safety switch but it appears fine).
Out of obvious things to check/replace, any ideas from anyone?
