I have a 1984 35hp Evinrude Mo
I have a 1984 35hp Evinrude Model #E35TELCRR Serial# E0381436 that has lost top end power and rpm. Max rpm was 5900 & now won't go over 5250. Engine runs smooth but boat will barely plane. The motor is on a 16' Alumnacraft that I use to pull the kids around on tubes. It used to have just enough power to give then a decent ride. Would top out at 22mph. All of a sudden it won't plane and idles erraticly. It did seem to idle a little funny the last time I used it though. I did a compression test and #1 is 103lbs & #2 is 118lbs. This seems marginal according to what I have read. Do these readings point to a rebuild. I tried new fuel and new plugs with no change although I was not to hopeful.Grateful for any help. I am a retired auto mechanic with limited 2 stroke experience if it matters. Would like to get her going for when the kids come back at the end of the month. Thanks again.
Rick
Rick
