33hp Ski Twin
jdarcy
"Help!! I have a recently acqu
"Help!! I have a recently acquired 33hp Ski Twin which I think is a 1968 model. The engine ran fine about 4 weeks ago, but now won't start. I have spark, but I am not convinced that fuel is getting to the cylinders. I can see fuel in the carb, but the plugs seem kinda dry. Anyone have suggestions? Thanks"
"If you have compression and s
"If you have compression and spark, I would assume that either the carburetor is fouled, out of adjustment, or the choke isn't functional.
What is the model number of that engine?"
"Thanks for the quick response
"Thanks for the quick response. It is a model #33853R. I can rule the choke out, because the electric choke is no longer connected so it is now choked manually. Thoughts?"
"Your engine is a 1968 33hp Ev
"Your engine is a 1968 33hp Evinrude.
Check compression and spark. If those two items are present,the carburetor most likely needs cleaning and rebuilding, but try the following adjustments first.
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
When time permits, visit my store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
