330hp 440 will not go WOT
mariog
engines run great but today I
engines run great but today I tried to run wot but the starboard engine would not go past about 3200rpm. the port engine throttle goes to the stops but the starboard goes about 3/4 of the way forward while in gear. i tried to see if the throttle cable was loose or something but I really coulden't tell if there was any binding or something. could I be looking at the another problem?
"Linkage problems. Pull the e
"Linkage problems. Pull the end off the carb and see the carb, then the throllte cable, will move all the way open. Fix the one that doesn't.
Jeff"
