330 TRS drive plate 1980
tracy43
Does anyone know where I can buy this drive plate? Or do any other drive plates fit? The part number is 77480A-1.. no longer available through Mercruiser . thanks..
If you mean the one that bolts to the flywheel then they are car clutches without the fibre material
Might have to by a clutch and remove the material
It is the plate that bolts to the flywheel.. but the splines need to match a merctrans transmission input shaft
